1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
- None, looking now!
I'm stretching my 121 incher to 136. When I do this, will I have to relocate my upper 2 wheels that the track rides on? What gearing should I have and what drivers? Keep in mind, I will be at 260hp with turbo.
I'm getting my sled ready for the turbo later this year, I've got the 8" wheels comming should look pretty cool. I got the flame wheels. Should look great on my RTX. I thought there was a guy on here that did his RTX also, but I can't find the thread. Would like to see the pics of it so I can have a visual.
Vince
Vince
ya that was me who stretched out the RTX. There is another guy on here who has done it as well. I used an actual 136" monoshock as opposed to stretching my stock rails and yes it does add an extra set of upper wheels. If you go with a rail extension kit I'm not sure how or if the company's address that issue.
I have not decided on drivers yet but a lot of the whos who in the turbo world say ski-doo extroverts are the best driver for a turbo sled. I'm going to do a little research before I make a decison though.
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
Yeah, I hope the upper two wheels aren't an issue. The angle coming back up into the tunnel from the top of the rear wheels will be tight if I leave the stock ones where they are at. I'm not sure if this is an issue or not.
1CS
1CS
dirkdiggler
Suspended
1CrazySledder said:I'm stretching my 121 incher to 136. When I do this, will I have to relocate my upper 2 wheels that the track rides on? What gearing should I have and what drivers? Keep in mind, I will be at 260hp with turbo.
Vince
You cannot lenghten the 121 Mono to 136. There are some guys going to 128 but that's about all you can go.
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
Dirk,
I have never heard that before. I have rail extensions coming from rich for my sled. What makes it imposable to stretch a 121 mono?
Vince
Vince
LazyBastard
Its because the rail extensions flatten out the return angle. When the suspension compresses, it will cause the track to tighten up like a banjo string and will prevent the suspension from reaching full stroke. This will ultimately cause significant damage to suspension and track.
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
LazyBastard said:Its because the rail extensions flatten out the return angle. When the suspension compresses, it will cause the track to tighten up like a banjo string and will prevent the suspension from reaching full stroke. This will ultimately cause significant damage to suspension and track.
Okay, heck with it. Will an expert X with 136 ext. work well for cornering, off the line etc. Or should I go with an M-10? Keep in mind I'll be boosted at 12lbs.
I wonder why people sell extensions for the 121 mono if it will cause damage.
Vince
