good miles this past weekend
Bluebullet
Massena NY
2021 sidewinder LTX GT, 2010 Apex LTX GT
LOCATION
Maine
My set up is much improved but still room to tweak some for sure. here is my last set up:
Now set :
10.7in or 274mm track off ground
9.33in or 238mm on floor no rider weight
Sag is 1.70in or 43mm with 220 lb rider weight
Sag reading per my manual instead of just reading the lenght of spring
measuring from sping bottom to center of mounting bolt is 1.7in or 43mm
Front shocks are set at 8 and 8 clicks with no preload
limiter strap is last hole full limit.
I made minor tweaks on trail. moved control rod two threads to less transfer. adjusted top cliker down to 7 from 8 on front shocks
Still have to light of sterring in front. Rear skid rides much better. should I try the CR for less transfer, tighten front springs some? Don't want to mess with limit strap?
Rode an 09 lTX ( same as mine) and handled great rode great? wth? He has the base model no front clickers and no electronic shock.
Can I match his set up?
What do you guys think?
i cant get my sled to turn unless the limiter is sucked up and the transfer is down. starting to think that shotgun track is the answer after reading many posts. there is a lot of grip from the rear and it doesnt want to change direction unless theres ski pressure and less transfer. if your sled is rotating well then just add some ski pressure until it isnt any better
