87gtNOS
- Nov 30, 2005
- Toronto
- 12 Apex XTX MCX powered
Gonna swap skiis, but can't get one of the mount bolts out! Beat the heck out of it, won't budge!
Sheesh...
Sheesh...
Macheater
- Feb 7, 2006
- Niles, Ohio
- 2006 Apex GT, 2002 SRX700
- Niles, Oh
Yea they can be a PITA! I've gotten in the habit of pulling mine a couple times during the riding season and greasing them along with the suspension. If ya don't the bolt corodes with the collar. Like what you're experiencing. Keep pounding they will eventually come out.
Btw it would probably be a good time to replace that collar along with the bushings in the knuckle.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Have someone "backup" the other side of ski so it's not bouncing. Use a big chunk of metal to back it up.
Put a little heat on just the bolt then let it cool... do that a few times and then beat on it.
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
Remove the spindle and mount it in a vise, spray it for a couple days. It's a seasonal thing to grease the bolts and bushings.
RAMSOMAIR
Never Seez is your friend when you finally get it out and re-assemble.
87gtNOS
- Nov 30, 2005
- Toronto
LOL! Thanks guys, the ski and spindle are in the back of my truck...taking them to work tomorrow to beat on them some more, but with a bigger hammer!
Now your talking!! Beat the SOB
Macheater
- Feb 7, 2006
- Niles, Ohio
- Niles, Oh
LOL Right on!Now your talking!! Beat the SOB
Or if ya have acess to a press. Just press it out.
87gtNOS
- Nov 30, 2005
- Toronto
Had my friend hold the ski and I beat it with a 3 lb sledge hammer! LOL! Sucker finally moved!
87gtNOS
- Nov 30, 2005
- Toronto
will coat the bolt with anti-seize when I put it all back together! LOL
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
Grease would be my option.will coat the bolt with anti-seize when I put it all back together! LOL
RobX-1
- Coldwater, OH
You may also want to look into replacing the sleeve (#13) that the ski bolt goes into as well as the two bushings (#29). I did this on my 08 Apex LTX last year primarily because it has over 13K miles but considering how rusted your bolt was, this may be something to consider.
RobX-1
- Coldwater, OH
Those shims can be a PIA to remove but I just used a long regular screwdriver and hammer since the thickness of those shims is very small and the chisels I had were a bit too large and kept sliding off of the edge of the shim when hitting with a hammer.
87gtNOS
- Nov 30, 2005
- Toronto
I ordered the new sleeve on Monday. I have not looked at it since I got the bolt out though. I did also order the spindle bushings as that is where I have slop....I think I have over 14000 kms of Turbo ski lifting! LOL
