dlinebacker36w
Rolled viper over and messed up a arms and shock on left side and got it in the shop took belt off and get track off the ground give it any more throttle and it stalls. It idles fine starts right back up. Is there some crazy sensor that could of got knocked loose or something. Thanks
My guess is throttle over ride. Check throttle and cable. Is your oil light on?
stingray719
Start and stop it about 5 times....because if you lose oil pressure it will do that.
Simple little switch on throttle block that detects a stuck throttle. I'd guess since it went over this is the first place I would look. Switch needs to pop out when the throttle is opened or it will cut ignition.
stingray719
Oh, also if you don't wait for it to warm up enough (until red light goes out) it will do this also.
dlinebacker36w
Thanks TD max u hit it on the head
Actually Cannondale said it, I just explained a bit more.
dlinebacker36w
Thanks for all the help and info
justin cameron
- Aug 1, 2014
- 2014 viper xtx
Let it warm up like said previously in the post till light goes off, should fix your problem
- 7K
