Robinmaine
So I wanted to mount my GPS and not disturb, drill or have restricted acess to the pod or dash bag. So here is what I came up with. It's a handle bar ram mount. I just fished the u bolt through the riser with the bar reducing shim in. I had to grind a 45 on the ball mount it self where it meets the riser. It was a touch to large to fit. I generally only use the GPS at intersections on trail I don't know. So it being down isn't a big deal for me. The picture is representative of where I would be sitting. It's about 6" above the fuel cap.
Robinmaine
Robinmaine
TD Max
Here is how mine ended up last season. For this season I am working on upgrading to a 7" unit.
DeerHuntr
DeerHuntr
DeerHuntr
Robinmaine
I like those!
Sent from my SM-T817R4 using Tapatalk
sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
If you can find a lake effect riser they have the ram ball mount built in.
rbell14
OSP makes a nice mount bracket that puts the GPS right above the gauges. Uses the two factory bolt in that area to attach. From there I just Velcro the GPS to the bracket. Works great.
yzf1999
- Dec 25, 2006
- Bloomington, Illinois
- 2015 Yamaha SR Viper LTX SE
I did the OSP mount for my nuvi a few years ago..http://ty4stroke.com/threads/nuvi-50-install-pics.136186/
ck7923
That's strange - I just took delivery of my 8 inch riser from Chris, I don't see that.If you can find a lake effect riser they have the ram ball mount built in.
sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
Maybe it's an option. He drills and taps one of the cross braces and threads a ball in there. I guess anyone with the skills could do there own.
http://www.rammount.com/part/RAP-B-379U-252025
tveiten1976
- Aug 4, 2015
- NO
- Norway
- Yamaha Viper M-TX 141 SE
I used a Garmin Montana marine mount on mine. No drilling, just used the existing holes in the riser.
tveiten1976
- Aug 4, 2015
- NO
- Norway
There's also 12v cables so it turns on when sled fires up.I used a Garmin Montana marine mount on mine. No drilling, just used the existing holes in the riser.
And a quick release.
- 7K
