GREEN SPRING IN SECONDARY 03 RX-1
mxkelly
I want to try a green spring in the rear clutch what would be a good starting point using stock weights and spring in prim..,, I think 60 is OEM for pink rear..... and green is a softer spring......... or is stock spring the better choice??
What are you hoping to improve by changing your spring?
I have the same thread basis going on right now.....its a toss up between the Orange-Silver-Orange and the Green-Silver-Green.....you can also drill out the tip rivets for a few more rpm....
I have read some articles on the web that the stock pink is too thick and will coil bind before full shift out can someone verify this or is it false info??
It looks to me like "mxkelly" was talking about the Secondary Spring. How did we get on the Primary (e.g. OSO, etc.?)
