vipermike2002
- Jan 19, 2006
- Barrington, IL / Rhinelander, WI
- 07 Attak
2005 RX1
I hear a grinding noise from the brake area when the sled is first accelerating forward like its not engaging in the forward mode completely. It does accelerate OK and does not make this noise in reverse.
Is there a adjustment to make it engage better or could it be something else?
Thank You
Thank You
JROCK
- Oct 25, 2007
- Ottawa, Ontario
- 2006 Yamaha Apex GT
Could it be possible that your reverse adjustment is totally out of wack or not returning? Sounds like its stuck in reverse and when you want to go forward its grinding the gears. Just a thought.
Your going to get one of your posts removed for double posting.
vipermike2002
- Jan 19, 2006
- 07 Attak
Sled Dog said:Your going to get one of your posts removed for double posting.
Not sure how active this forum is or what section this issue should go in, that's why I posted in two locations. Going up north tomorrow and I want get as much info as I can on this.
If a mod wants to merge the posts into the thread posted in the best section lock the old thread and put a link to the other one that's fine.
yox185
