I couldn't find anywhere that this topic had been covered yet so here goes.The grip and thumb warmers just plain suck on my '19 Winder,no getting around it.What I'd like to know is has anyone found a way to get this system to actually function better to get the heat out of it like it should? Does the RoczToyz kit help? Any other tricks to get more heat out of the grips and thumb?Travis also has his Japan thumb warmer kit but I'd like to be able to get more out of both circuits.
mike800
- Jan 20, 2022
- Anoka County, Minnesota
- 137" Procross
SPI cork wrap covered with RSI plug-in grip heaters followed by ODI or RSI soft grips.
![](/styles/vip.gif)
Really? I couldn't be happier with mine. Waaaay hotter than the all-Japan models.I couldn't find anywhere that this topic had been covered yet so here goes.The grip and thumb warmers just plain suck on my '19 Winder,no getting around it.What I'd like to know is has anyone found a way to get this system to actually function better to get the heat out of it like it should? Does the RoczToyz kit help? Any other tricks to get more heat out of the grips and thumb?Travis also has his Japan thumb warmer kit but I'd like to be able to get more out of both circuits.
Mine are plenty warm. One of my buddies has been riding with mechanics gloves, not sure of the brand but he convinced me to try last season. So much warmer, hot actually. This year I will be looking for a glove with minimal insulation on the palm side.
stgdz
- Mar 27, 2021
- Buffalo MN
May have a short somewhere.
Ohm all three and check output voltage to them.
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
I use the fxr transfer gloves and my hands burn on high, most guys who complain about cold hands on the procross are wearing to thick of a glove.Mine are plenty warm. One of my buddies has been riding with mechanics gloves, not sure of the brand but he convinced me to try last season. So much warmer, hot actually. This year I will be looking for a glove with minimal insulation on the palm side.
SAB1
- Mar 1, 2011
- Tuftonboro NH
- 2017 Sidewinder LTX SE
2010 Vector GT
2006 Apex
Same for me. My grips and thumb warmer are great. Rarely do I use on anything but low. Often shut them off as they get hot.
markt111
Hand Guards, no glove works well if you cruise at 100MPH
I run PowerMadd Sentinel and added the Armour!!!
What length heaters did you use? I see there's 2 options,standard and extended.I thought the factory ones covered the hooks but maybe they don't?SPI cork wrap covered with RSI plug-in grip heaters followed by ODI or RSI soft grips.
I use Sentinel guards now but no Armour added.I wear FXR Fuel gloves for colder days and the Klim ( Yamaha branded ) Power X Cross gloves for warmer days.I just seem to have a really hard time keeping my hands at a comfortable temperature with this sled.They're either too hot or cold.Hand Guards, no glove works well if you cruise at 100MPH
mario750
I had Yamaheater mod for thumb warmer and it worked very good, on hi settings I was getting almost burnt after while. Before mod in temperature below 20f thumb warmer wasn’t enough even with hand guards on sled.
markt111
The armor makes all the difference, I used 4 year old Katahdin gloves all year with no issuesI use Sentinel guards now but no Armour added.I wear FXR Fuel gloves for colder days and the Klim ( Yamaha branded ) Power X Cross gloves for warmer days.I just seem to have a really hard time keeping my hands at a comfortable temperature with this sled.They're either too hot or cold.
markt111
Boston RX1
I have an 18 LTX SE and use the Klim gaunlets and run thin Klim gloves. 95% of the time i do not use any heat in the grips. I have been out in -25 F with the grips off most of the time. I do find that when the grips are on, there is a wide range of temperatures on the same setting.
Turboflash
- Mar 18, 2019
- Southern MN
IMO "comfortable" hand/finger temp varies greatly from rider to rider. What is comfortable for one, might be too cold or too warm for someone else. It's like room temperature. For those of us more "mature" riders who have frostbit our hands a few times (back in old days, handlebar heaters weren't as common nor did they work as well as today, and glove technology was not as developed as it is now) my hands are more sensitive now and get cold easier for sure. That changes the whole equation for sure.
- 12K
