Big Bertha
- Mar 1, 2023
- 2018 VK PRO 2
When using the older Japan model clutches on the Sidewinder, the weights need to be heavier. I installed a 2012 Vector clutch on my 2017 Sidewinder and had to add 4.5 grams to each weight. If you are trying to install a Sidewinder clutch on your VK, you'll have to do the opposite and make the weights lighter. The reason for this is the position of the roller in relation to the weight, if I remember right. For more/better information about this, contact Thunder Products Clutching.
Oh I see. ( totally nube question here. Know nothing about these things) so if I run the Winder clutch in my VK as is, what will happen? What would be the difference with the heavier weights? And, is the Winder clutch weaker in its construction then the VK clutch? Why do people change them?
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
I think it is the position of the weight/roller to the center line.The reason for this is the position of the roller in relation to the weight, if I remember right
The Sidewinder clutch places the weights/rollers farther away from the center line, letting lighter weights apply the same force as a heavier weight that is closer to the center line.
That is why you need a heavier weight in the old clutch vs the weight in the Winder clutch-----in most(?) cases..
STAIN
- Feb 29, 2004
- Vermont
- Vermont
People have been changing back to the Apex/Rx-1 clutch to gain durability. There have been many instances where a Sidewinder that has been wearing rollers has been cured by going to the older Apex clutch.And, is the Winder clutch weaker in its construction then the VK clutch? Why do people change them?
It has been thought that the construction of the Sidewinder clutch allows for more flex, maybe due to Yamaha farming out that clutch to China for construction.
I took my brand new clutch off my 22 GT and installed a rebuilt Rx-1 clutch. I had the clutch in stock, otherwise I probaly would have tried the stock one first.
twyztid
- Feb 14, 2011
- Middleville, MI
- 2025 Sidewinder LTX LE EPS
2025 Sidewinder LTX LE EPS #2
2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
If you put the Sidewinder clutch on with your VK spring & stock VK weights, you will likely under-rev because your weights are too heavy.Oh I see. ( totally nube question here. Know nothing about these things) so if I run the Winder clutch in my VK as is, what will happen? What would be the difference with the heavier weights? And, is the Winder clutch weaker in its construction then the VK clutch? Why do people change them?
twyztid
- Feb 14, 2011
- Middleville, MI
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
You are likely much better off buying the correct clutch.Oh I see. ( totally nube question here. Know nothing about these things) so if I run the Winder clutch in my VK as is, what will happen? What would be the difference with the heavier weights? And, is the Winder clutch weaker in its construction then the VK clutch? Why do people change them?
This one looks nice.
2012 YAMAHA RS VIKING PROFESSIONAL VK10 Primary Drive Clutch | eBay
Find many great new & used options and get the best deals for 2012 YAMAHA RS VIKING PROFESSIONAL VK10 Primary Drive Clutch at the best online prices at eBay! Free shipping for many products!
www.ebay.com
Big Bertha
- Mar 1, 2023
- 2018 VK PRO 2
Ok, great info. Thank you all very much. I guess I’ll put this Wider clutch on and see how it does. I’m in tight trails on my property and will only pull the occasional tire to make walking trails. And maybe a small blast up and down my fields. Nothing too crazy that’s for sure. I just hope it works good at slow speeds. I hope it will engage right off idle.
Big Bertha
- Mar 1, 2023
- 2018 VK PRO 2
Hey all, what’s the torque value on the primary bolt for the VK? Is it 80 pounds then back it off and put to 40 pounds? Thanx.
85 ft/lb initally and 43 ft/lb as final torque.
