Snorover
- Apr 15, 2003
- Kittery/Fayette,Maine
- 2017 Viper
My guage is dead on my 2017 Viper and I need to know where to start looking to correct this as I have not been able to find anything on here, so far.
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
Did you check all the fuses? Happened to mine also, sled wound start up fine but no gauge, ended up being a fuse.My guage is dead on my 2017 Viper and I need to know where to start looking to correct this as I have not been able to find anything on here, so far.
Snorover
- Apr 15, 2003
- 2017 Viper
I only checked the one that said ISC and it was ok. I'll check the rest of them, next.My guage is dead on my 2017 Viper and I need to know where to start looking to correct this as I have not been able to find anything on here, so far.
Snorover
- Apr 15, 2003
- 2017 Viper
I found that fuse labeled tail light,Dash and Accy was bad, so replaced it (20 Amp)My guage is dead on my 2017 Viper and I need to know where to start looking to correct this as I have not been able to find anything on here, so far.
ksiesel
- Mar 25, 2016
- Columbus, Indiana
- 2015 Viper RTX-DX with QS3’s, winder jackshaft, RR front arm shaft, 4 wheel kit, and many more upgrades
- Columbus, Indiana
If you have a heated shield cord without it's own fuse, it's not uncommon for those to short against the chassis and blow this fuse.I found that fuse labeled tail light,Dash and Accy was bad, so replaced it (20 Amp)
I put a fuse between the accessory plug and the heated shield jack at around 5 amps just to avoid this fuse blowing. Knock on wood, I haven't blown either yet, but I'd much rather only have a heated shield not work than a tail light and dash also not work.
I have a speedometer gage/ dash from a 2019 winder if needed—- 3800 miles on it—
Electric shocks?I have a speedometer gage/ dash from a 2019 winder if needed—- 3800 miles on it—
Yes— 2019 sidewinder LTX LE with IQS
but you don’t need the IQS correct?? IQS does not show up on my dash, that is why it was replaced all other fuctions are good—- Tod 2607019033
