yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
My Rt hand warmer is not working, last 70 miles of 300+ week end. What to check?
Wire to warmer looks good, grip itself looks normal just Rt cold left warm.. Is there a fuse to specific rt v. lt? Lt works great/ normal.
Yamadoo aka Mark
Yamadoo aka Mark
theCATman
- Feb 19, 2007
- WI
- Yamaha
Warmer fried out. I had mine do the same thing last winter (although mine was the left side)
Time to call good 'ol Kevin at Port Yamaha. Get a warmer, grip, grip glue, & rivets ordered.
You WILL ruin the old grip getting it off, so don't even try to be gentle. Just get out the box cutter & slice that baby right down the middle & peel her off.
theCATman
- Feb 19, 2007
- WI
- Yamaha
One more thing... I know Yamaha supposedly upped the stator output to help with the warmers, but you know the big thing they did was just wire them in series. That's why they get blazing hot. Too many times on 3/4-full power takes it's toll on them.
yamadoo
- Jun 3, 2003
can I just cut the wire and solder it to the new or is their a junction to go to I can just pull apart and snap in?
Thanks I was afraid it might just be new grip.
theCATman
- Feb 19, 2007
- WI
- Yamaha
There is a junction down in the upper steering column. Don't cut the wire.
Snap together bullet style connector. Follow the wire from grip down, you'll find it.
lockburner2000
- Feb 15, 2010
- Bruce WI
- 2010 Vector GT
If you have a heat gun you can save the grip. Just heat it up and it will twist off. I have reused both of mine on a 2010.
Grips are expoxy'd at the ends. Heat and twisting will help get it off.
To test the grip remove the dash panel and find the two white connectors with 2 thin black wires leading up to the handle bars. Unplug and grab an ohm meter. Put each of the ohm meter leads to each side of the connnector with the black wires. A good grip will ohm out at roughly 3.5k ohms. If its not close or open then the grip is toast.
I replaced my grips with the Yamaha kit from RSI. Came with new grips and heating elements which were much nicer than stock.
yamadoo
- Jun 3, 2003
Thanks guys sled is at the cabin, no heated garage going to be COLD so I may just pay to have it done not sure the epoxy would set up at 10 below or that I want to work in those temps
yamadoo said:My Rt hand warmer is not working, last 70 miles of 300+ week end.
Wait a minute! Were you not supposed to be taking care of your grandkids that weekend?
Just bugging you. You were missed at the TY Ride.
yamadoo
- Jun 3, 2003
Yep, wife helped out and I could go friday late 4 pm, satuday and sunday.
Did you guys have a good trip in Manitooba?
We call our little trip the "adventure" so many stuck episodes, catastrophic failure of a AC ZRT, and some belts and of course my code 43 and hand warmer.
Mark
Mark
