jtssrx
What is the tallest riser anyone has used with the stock cables.
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
I'm installing a 2 incher tonight. I was told you can go 3 inch but would be pushing it.
4stroker
BBY has this in his vendor area....
http://www.rx1.info/viewtopic.php?t=6209&postdays=0&postorder=asc&&start=15
welterracer
See Dan even BBY says that anthing over a 1.5 puts tension on the cable.. 3inchers would be near impossible!
I cut my 2 incher down to 1.25
Brian
Brian
touched
I made an installed a 1.5 inch riser last year and had plenty of cable length when turning the bars. 2 inch riser should be fine.
98srx6
- Feb 2, 2004
Thumper1000
I put a 2" on my 05RX1 and it seems ok, have not ridden yet but started it and turned bars both ways and no problems. I don't think 3" would make it, it was almost getting tight with the 2".
Yamahnator
Have a 2 inch on my 04. Works fine, just make sure nothing is hanging up. I had them put a 4 inch that I had bought on my 05. They ordered mountain cables for it.
Mighty
- Apr 17, 2003
- 22 Mach Z
23 Sidewinder SRX
I just installed a 2 inch riser and when I turn all the way right the throttle cable tightens up and yanks on the carbs giving it a little gas. I may try to re-route the cable under the bars instead of over.
Blue Me
Spend the $18 and get the mountain cable. Then get yourself a 3" riser
monker
I have a 3". Re-routed the brake line and e-brake cable. The longer throttle cable is worth it.
Mighty
- Apr 17, 2003
- 22 Mach Z
23 Sidewinder SRX
Yep, I just confirmed that the mountain cable is needed on my sled :ORC
