GT03235
My handle bar warmers have always been um not that warm but now the right one has stopped working all together aren they fused seperate? any fuse at all? any ideas!
revster
- Aug 18, 2004
- La Salle MB
- 2009 Yamaha Nytro RTX SE
GT03235 said:My handle bar warmers have always been um not that warm but now the right one has stopped working all together aren they fused seperate? any fuse at all? any ideas!
Is it me or does it always seem to be the right one?
For me it was the warmer itself that quit. I replaced it was the RSI kit from Yamaha, spary foamed my bars and got better hand guards now I can't run them on high because they are too hot even on cold days.
09nytro
The rsi grips work great . Put them on my sled always run 2 to 3 bars . I hooked them up red/blue together
GT03235
i appreciate your time guys but it still does not answer my question?
chaserdog
I doubt that they are fused seperately, you probably have a fuse that would protect both hand warmers and thumb warmer. More than likely the element burnt up in your right side. You could check the resistance in the elements to see if one opened up. I do not know what the resistance should be but contact your local dealer they should be able to tell you.
revster
- Aug 18, 2004
- La Salle MB
GT03235 said:i appreciate your time guys but it still does not answer my question?
I don't believe you have a fuse problem....
http://www.ty4stroke.com/viewtopic.php?t=83992
09nytro
Right element is bad , Replace it
NyTrOMaNIaC
My right element went on my 2010 MTX SE a couple weeks ago, had to get a new one from the dealer, going to replace it tomorrow. 750 kms on the sled and kapuut !!! Don't know what happened, it just quit. Seems to be quite common that the right elements are quitting, they were on backorder if that means anything.
sleddingfarmer
Left one quit on mine. Grips will twist on the bars and eventually it just tears the heating element. Cut your grip off and you will probably see where the element is tore/ripped.
GT03235
sleddingfarmer said:Left one quit on mine. Grips will twist on the bars and eventually it just tears the heating element. Cut your grip off and you will probably see where the element is tore/ripped.
Yes thats what has happened
yox185
Get the update kit from Yamaha (RSI). Grips are much warmer and the texture of the grip is better. It has a knurled pattern and is very tacky.http://www.yamaha-motor.com/sport/a...1829/18740/all/1/10525/0/main/itemdetail.aspx
stephenpen
I put 06 Apex bars on my nytro for $25. They get really hot real fast. I leave them at 2 bars. They plug right in.
Check the classifieds
mcamzr
Do your self one better and pass on the yamaha grips in the kit and put a set of the ODI's on from RSI. They are way better. They are a bit thicker so yu should foam the bars and you'll also have to cut about an inch off.
NyTrOMaNIaC
They shouldn't twist if the rivets are in place. I just went out a tried to twist mine and there's no way I could budge it. Even worse, my dealer got me a left side element because the right side is on backorder, but the path of the wires exiting the element itself obstructs the throttle, so I can't install the new element
mcamzr
NyTrOMaNIaC said:sleddingfarmer said:Left one quit on mine. Grips will twist on the bars and eventually it just tears the heating element. Cut your grip off and you will probably see where the element is tore/ripped.
They shouldn't twist if the rivets are in place. I just went out a tried to twist mine and there's no way I could budge it. Even worse, my dealer got me a left side element because the right side is on backorder, but the path of the wires exiting the element itself obstructs the throttle, so I can't install the new elementI am not a happy camper right now
If you haven't already done so check with RSI, that's where yamaha gets them anyway or at least when I opened my yamaha upgrade kit from the dealer they had RSI all over them.
