Well do you have the throttle cable adjusted correctly... but the correct slack would not prevent it from firing up... Make sure all the vacuum lines are on tight on the throttle bodies.Yes it does thanks. Just doesn't explain why I had to do 3 or 4 turns out to get it to start properly when I never touched it. I was originally thinking throttle cable.
