RX-1snow
I had my first ride on my RX-1 and had to give it some throttle to get it to start. I bought this sled used and had the carbs cleaned prior to using .At that time it was stock but I have since installed green ( holtzman) springs . Does this hard starting requiring throttle mean it has no gas available or too much ?? I tried idling up to 1600-1800 RPM but did not help . Anyone else have this problem and did you fix it?
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
Everyone I know of requires you to crack the throttle just a pinch when warm and she'll fire right up. Thank god for electric start, can you imagine cracking the throttle with one hand while you pull the starter rope with the other :shock:
Red RX1
I had the same problem last year. Only when it's hot I had to apply throttle to get it to start. I discussed this with my dealer and they made a throttle cable adjustment. They also did other recall repairs. I have yet to make a run and see if the problem is solved.
RX-1snow
Has anyone out there had this problem and fixed it ???
You need to install a coolant shut off for the carberators. It often helps to stil crack the throttle but it will fire immediately. Without the shut offs it can be a real bitch to start after it gets warm. The problem is magnified greatly if you have a mountain sled with the new deeper float bowls.
The above works, but I am wondering if another potential cure is to reduce the size of the starter jets?
Black 1000
I have had Yamahas for many years and I have ALWAYS had to crack the throttle when starting hot. Just a Yamaha thing.
Tom-RX1
I had it on mine and dealer fixed it starts with no problem now
Tom-RX1
Tom-RX1
rep
Any tip on installing the coolant shut off? Plan on doing it tomorrow.
sanks
sanks
Just cut the coolant line and put it in. Leave it open just a little tiny bit.
BlgsRX-1mtn
- Apr 16, 2003
- Billings, MT
- '03 RX-1 Mountain LE
Just do as Ray (Spray25) said. I bought a brass ball valve and the nipples to fit the hose along with two hose clamps for about $6 US. Here is a pic of it installed.
GUKROKIT
Motion pro makes a nice shut off valve.Page295 dennis kirk 04 sled catalogue.It's compact almost looks oem,has a small red knob on top part#18-0690 $13.99
ExTrEeMF7
BlgsRX-1mtn said:Just do as Ray (Spray25) said. I bought a brass ball valve and the nipples to fit the hose along with two hose clamps for about $6 US. Here is a pic of it installed.
i dont mean to hurt your feelling but that looks like #*$&@..
looks mickey mouse.. Sorry ... but had to say it ...
POWERHAULIC
I used a ski-doo shutoff, $10-12 as I remember.
ExTrEeMF7
mxz900 yeah me too . looks realy good and looks like it was part of it already
SrXxTrEeM said:BlgsRX-1mtn said:Just do as Ray (Spray25) said. I bought a brass ball valve and the nipples to fit the hose along with two hose clamps for about $6 US. Here is a pic of it installed.
i dont mean to hurt your feelling but that looks like poop..
Well I like it. Looks ok and gets the job done for a good price. Marc, you definately wouldn't like mine. It's even uglier than Blgs valve.
