hard warm idle stalls
Age
34
Canada
Yamaha apex gt 2006
Hi everyone how are you my name is Jocelyn im new and i speak french so i will do my best to be understood.
I have a 2006 apex gt
Cold start is very good
Then when it begin to be warmer the rpm decrease to 1500 (good)
As it heats up more and i give gas (below 3500 to not engage the clutches).. It will drop down to 700-900 rpm and run very rough and stalls.
I put key off.. Hold a bit of throttle and starts fine again.. But will stalls again.. Always when hot only.. Even in the garage
My battery is good
I put new spark plugs
Sled has 21 000 km
My tps values in the speedo are 19-96
My CO's are all -10.
Would i need a valve job ? Valves wont seat properly when they are hot and expand ?
Thanks a lot
Hmmmm 2yrs ago hard to really say what it is.any codes on dash .have you drove it around and get it up to temperature and blow out the carbon and exercise everything .
Had code 12-22-30-84
Changed the pickup coil
I cleared them
They are old codes . they dont come back .
My tech said he would adjust the valve clearance because its stalling only when hot engine
Is he right ?
Ok .if they dont come back take the machine out if you have snow and run it and see.if no snow find a stand or some lift to spin track and get warm.
He maybe right ,check -lots of variables .
Yes i have a stand to spin the track. I did it.
Its really when its warm. I have to play with throttle .if not stalls immediatly.
The big black plastic idle valve screw doesnt change anything really. Cant seem to work because when warm it want to stalls..
Ok .some guys have good luck bringing the C0 numbers down more .you said you have -10.bring it down more ,.try this first and see. go down to -20.
Cant believe its valves with the miles.i have sportbike like my own with more miles with more abuse and valves are fine
I have always started my machine 1 a week since i bought it new ,every week for the past 8-yrs. always run Yamaha fuel products in everything i own and i have no issues with running or starting.
I am a firm believer in doing this and will not stop.
I have seen fuel and carbon and ruin things.
Maybe the guy that owned it before ran it hard.__ Nitrous ?
I dont know the first and i dont believe it was hard ridden honestly. There is something wrong that someone could know the prob.. :(
