jrice1987
So I have a grounding problem at the ground coming out of the harness, (grounding block i assume) If i run a ground from the battery to hand warmers I get 12vlt and warmers work and blinking light goes out. Soo... the hand warmers, thumb warmer, and thumber warmer switch work off the same ground. So can I just run a new ground to battery and splice all 3 in?
sounds like you need to find the ground block and fix it as well as it will most likely cause issues further down the line.
jrice1987
It was 2 ground blocks corroded under handle bar dash
good you got it.
