dfroster
- Dec 18, 2003
- Kronenwetter, WI
- 2022 Arctic Cat Thundercat EPS
Any way to reduce the harsh clutch engagement? Want to get rid that initial jerk that comes if you don't open the throttle ever so gently. Different clutch spring maybe? Thoughts? Thansk.
YamahaFreak
The Pen is Blue
Try a different spring in the primary, so it revs a bit before engaging.
I just ordered a Comfort Clutch kit from Schmidt brothers. This is supposed to cure this. Hope to have it by the weekend...
YamahaFreak said:Try a different spring in the primary, so it revs a bit before engaging.
I would think lower your engagement I ride mountains but I like the lowest engagement I can get. The Nytro has so much bottom end power that it has no problem pulling a low engagement.
My thoughts would be that I think you have a Y-S-Y spring that is 35-118 you could try like a G-P-G that is a 30-121 and that would lower it down for ya without changing your shift much.
Zakre
How many miles on the belt, after 3000 beat on miles my belt was engaging very abruptly, put on a new one after i blew the old one apart lol , shes smooth as silk again.
nor'easter
I guarantee that you will like the Schmidt Bros. kit if you are looking for a smooth engagement on your clutch. You gradually press the throttle and the sled moves very smoothly.vector06 said:I just ordered a Comfort Clutch kit from Schmidt brothers. This is supposed to cure this. Hope to have it by the weekend...
mach9
Most decent clutch kits cure this problem.
If I had of known back in 09 when my XTX was new.
I would of ditched the stock clutch weights before my first mile.
The stock clutch set up spins and gooves the primary sheaves down low because there isn't enough squeeze on the belt early enough.
Just installed the Comfort Kit. Sled is way way better now. No more snapped neck for me..
Prarie Dawg
Had my clutching done by Boss performance. Very smooth engagement now. Do a search to find the threads.
Snowman269
- Dec 2, 2004
- Baraga, MI
- 06' Apex
14' KTM 500 EXC "SnowBike" fitted w/ 15' Timbersled LT
07' Phazer
rlcofmn said:YamahaFreak said:Try a different spring in the primary, so it revs a bit before engaging.
What do you have for engagement? I also like a low engagement, I just wasn't sure how low I could go with this torque monster. i want to be able to crawl through the trees without blowing the track loose until I want to.
Last weekend I got the belt smoking pretty bad trying to keep from making a hole and getting stuck. I am running 22/38 gears 68l straight chain. I know I should gear down to stock too.
My Attak was excellent that way, you could just crawl along and maneuver through the trees, hardly ever spun the track. With the gear reduction that clutch had a nice low engagement.
craigwsrx
- Feb 19, 2007
- Fenton Mi.
- 2017 Sidewinder 27,000 miles
2009 Nytro xtx 31,000 miles
2006 Attak 26,500 miles
2003 RX1 13,500 miles
2000 Mountain Max 14,000 miles
1998 SRX Mountain 17,000 miles
1995 V Max 600
1979 SRX 440
1975 GPX 338
1973 GP 338
I installed a Schmidt Bros clutch kit and it works excellent, sled runs and performs great. I love the low engagment especially in reverse, it makes it very easy to back up without liting up the track.
yamakazie
With the Schnidt Bros kit does it still have the low end rip your arms off pull that makes for nice wheelies?
nor'easter
Yamakazie - I would recommend their stage 2 kit which has the smooth low end engagement as well as improved pull throughout the entire power band. These clutch kits work much better than the stock set up.yamakazie said:With the Schnidt Bros kit does it still have the low end rip your arms off pull that makes for nice wheelies?
NFLD-Nytro
I looked at that kit, but there's no way I'm going to spend $250 or a clutch spring, 3 rollers, and a handful of screws. Just couldn't do it.craigwsrx said:I installed a Schmidt Bros clutch kit and it works excellent, sled runs and performs great. I love the low engagment especially in reverse, it makes it very easy to back up without liting up the track.
09nytro
Trust me by the time you get all the parts and then some you got a box full of part way more $$$$ and end up with same out come so getting the kit isn't that bad , bolt on and go play
