Apex short track
- Jan 20, 2020
- Manitoba
- 09 Yamaha Apex
I have an 09 apex and my heated thumb warmer is not working. There is no fuse in the fuse diagram so I don’t know what it could be. Any ideas would be great
have you ohm tested the element?
Apex short track
- Jan 20, 2020
- Manitoba
- 09 Yamaha Apex
No. How do I do thathave you ohm tested the element?
well you need a multi meter with a good battery 1st. then you trace the wires from throttle down to the connector and un plug it. then you ohm test/resistance across the pins in the connector that lead to the throttle.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
The lever should ohm test at around 41 ohms
Apex short track
- Jan 20, 2020
- Manitoba
- 09 Yamaha Apex
Okay that’s manThe lever should ohm test at around 41 ohms
