snowbiscuit
Could not plug helmit in jack on consol by gas cap and was plugged with solder when cable was made. Cable asm can be easily removed and drilled out.
Yamascotty
Thanks for the heads up.....Could not plug helmit in jack on consol by gas cap and was plugged with solder when cable was made. Cable asm can be easily removed and drilled out.
I tried mine and luckily it inserted just fine
Wouldn’t want to find out at the beginning of ride
RAMSOMAIR
Please take assembly to dealer so they can be aware and replace.Could not plug helmit in jack on consol by gas cap and was plugged with solder when cable was made. Cable asm can be easily removed and drilled out.
snowbiscuit
Dealer would not do a swap on the cable asm, wanted the sled. At that point I decided to do it myself.
RAMSOMAIR
sad
- 42K
- 6K
