Confused
- Oct 12, 2008
- Mound, MN
- '25 Sidewinder SRX #723
'24 MXZ 850 Turbo R Comp
'23 MXZ Blizzard 850 ETEC
'24 MXZ Neo+ 600
'88 SnoScoot
1976 SRX 440 #554
Ring seal is not perfect. There will always be a small amount of blow-by, even in the best engines. (This is what a cylinder leak-down test shows - how well the rings are sealed). Also, as the engine oil is heated, it expands and generates some oil mist/fumes/vapor. There is a small amount of pressure in crankcase/engine. That's the reason for the vent line that goes from valve cover to airbox.
Thanks, I'm still curious what force is on the crankcase in our engines. Now that I have an easy way to tap into it, next time I have everything apart I'll put a gauge on it.
