RacinJason15
- Jan 23, 2008
- Comstock Park, MI
- 17' Yamaha Sidewinder LTX DX
- Comstock Park
Hey guys i have left heat exchanger leaking around the mount for the upper suspension! anyone had this happen? how bad of a job is that to pull the exchanger? let me know if anyone has ideas on how to fix this as well! thanks jason
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Here's a link to a post on this. http://www.ty4stroke.com/viewtopic.php?t=101419
If you can fine a good epoxy and not JB weld, a clear is your best bet. The clearer the epoxy the stronger it will be.
lawmanbsi
tried a metal set epoxy on mine and that didn't work. I'm going to take it back off this summer. This time I'm going to have it welded. It looks like a lot of work, but its not to bad.
Sharp drill bits are your best friend
lawmanbsi said:tried a metal set epoxy on mine and that didn't work. I'm going to take it back off this summer. This time I'm going to have it welded. It looks like a lot of work, but its not to bad.
Really, they are like $165.00 each. I would think, replace it and not worry if the weld will hold. JMO.
