Alex069
- Nov 6, 2019
- Moscow Region
- Russia
- Yamaha Venture Multipurpose;
FXNytro XTX
Hi guys,
I think I'm experiencing some leakage in the center of a tunnel heat exchanger, right in the seam. Dtected some dry spot there...
Couldn't find any clear instuction on how to remove it in order to weld it.
Please, share some experience on it...
Or maybe it would be enough just to fix that micro-crack with LA-CO heat seal stik, epoxy stuff?
Hi guys,
I have had them welded on the sleds before. JB weld wont last long and is mainly a temporary fix.
Alex069
- Nov 6, 2019
- Moscow Region
- Russia
FXNytro XTX
I wonder, if it's possible to dismount heat exchanger on MP with minimal efforts, from the tunnel side?I have had them welded on the sleds before. JB weld wont last long and is mainly a temporary fix.
If its built like the Phazer there is a good chance it can be done. Lots of rivets to drill out.
livewire_101proof
I have had a couple welded in the machine. Dropped the suspension, tore down the chaincase to get the track and drivers out of the way, just raised up the rear of the sled with a chainfall.
Alex069
- Nov 6, 2019
- Moscow Region
- Russia
FXNytro XTX
So, no need to unmount the engine?I have had a couple welded in the machine. Dropped the suspension, tore down the chaincase to get the track and drivers out of the way, just raised up the rear of the sled with a chainfall.
livewire_101proof
Nope, with all that out of the way when u lift up the rear u can get right in there to weld on it.
All the front end is still untouched
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
As mentioned, they are mounted the same as in Phazers, just wider by 2 inches. Although I've taken one out while parting out a Phazer, it might be a lot of work on an actual machine. I'd try having it welded in place.
Alex069
- Nov 6, 2019
- Moscow Region
- Russia
FXNytro XTX
I wonder, which page in manual describes the process..
- 6K
