Heat Loc Hand skinz Guards
I just bought a trail series pair in all black, and will try them this weekend. I moved my bars forward and up slightly. If these contact the windshield, they will give a little.
I have a pair. I like them for cold days. I find them a bit restrictive in the twisties though. I like to slide my hand to the end of the bar when cornering and the way they get mounted interferes with doing that. My wrists actually got a bit sore because of this.
I have the trail model and they work pretty good at -28 C They r not as good as full muffs but a lot better than none. I used to have a set of the hand protectors but they r useless at blocking the wind. Just my .02c
Choko makes them as well but a little cheaper about $30
I have them on 06 GT. Work great, but do interfear a little with hook. I might look at some adapter in the summer. But when it's cold I can deal with it.
I purchased mine at powersports1. I found they keep the wind off. They are most beneficial in the cold weather when the wind is most severe. They are not as good as normal gauntlets but better then the hard ones. I did find if you use a thick glove you tend to hit the edge when braking. Overall they are good and meet my needs. 07 Apex.
