mytro
I have about a 100 miles on my Nytro so I'm still adjusting, I was wondering who has the fix for moving the heat off your left boot and pant leg saving you from soaked and frozen feet. Do I need to go back to the 12 rubber boot? I was in powder for 10 mins today and my foot was soaked, Baffin boots soaked right through..
GRRR....
GRRR....
snownutz
What year sled?
Stoli
a cheap route.... just take some duct tape and tape the inside of the bottom vent at your foot. Just make sure you are not closing up all the vents here - it will need to breath. Also standard Pet Screen from Home Depot and put it under the hood vents as a pre-filter to keep the snow out.
I also added the IP vent from OFT to release all the heat upwards - worked great.
www.oftracing.com
www.oftracing.com
mytro
billymx815
- Nov 17, 2009
- S. Berwick, Maine
- SXV Venom, RTX Nytro, SR Viper RTX SE
- Maine
Yeah...what year. the 2009 has a shield in place to help with that I believe...Other than that duct tape is always your friend.
YamaMTX
- Feb 7, 2009
- crosslake MN
- 2009 Yamaha nytro and polaris 600 rush
mine is a 2009 and mine gets wet also
billymx815
- Nov 17, 2009
- S. Berwick, Maine
- Maine
YamaMTX said:mine is a 2009 and mine gets wet also[/quote
Really? do you ride in a lot of powder? I only get the wet foot when riding off trail in powder.
YamaMTX
- Feb 7, 2009
- crosslake MN
Yes I do look for powder!!!
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
hers what I did,,,I took some two sided tape and slipped it in between the lowest body panel and the bulkhead areas...anywhere I saw light witha bright light under the sled while using a screwdriver to pry apart...then used duct tape to seal the footwell..on the backside..
- 9K
