Gottago06
- Feb 12, 2018
- Michigan
- 2006 attak
Where is everyone wiring in the heated visor cord if not using the 12v socket?
Carla 123
- Feb 27, 2017
- Manitoba
- 2015 viper xtx boosted
17 zr9000 precision stage 3
To the battery or there is a plug down by the chaincase
Wannaviper
- Mar 18, 2014
- West Gardiner, Maine
If you want your shield to turn off when the ignition turns off, as Upton said, there is a plug down by the chain case on the right hand side, and you can buy the heated shield plug that plugs into it at an Arctic Cat dealer, and presumably at a Yamaha dealer as well. When conditions are bad, I use my heated shield, even when I am stopped with the engine off, so I wired direct to the battery. Just be sure to use a fuse on the positive wire if you hitch direct to the battery.
Peter A
- Jan 29, 2010
- Long Sault, Ontario
- 2016 SRViper LTX-DX
Might want to consider this...
SMART SUPPLY Plug&Play Power Port
The RoczToyz.com SMART SUPPLY is a super quick, easy, Plug & Play multiple power outlet for your ride!
SMART SUPPLY has TWO 1 Amp USB outlets to charge/run anything with a USB cord.
You can easily charge/run your Phone, I-Pod, GPS, MP3 player, ANYTHING USB powered, as you ride!
Gottago06
- Feb 12, 2018
- Michigan
- 2006 attak
Thanks guys I went to my dealer and got the harness.
Gottago06
- Feb 12, 2018
- Michigan
- 2006 attak
So funny story, I finally got around to installing the harness and pulled the speedo sensor off the chain case. That makes a guys smile!!! Guess brake clean and rtv are in my future..
