hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Been working on heavy duty replacements for the nytro, apex/ vector. The Viper panel offers very little protection as well so I am going to produce replacement panels that are thicker. The BOP plates will be aluminum, but twice as thick as the factory plate. They will be a direct swap and mount with the factory hardware. Retail will be $22.
Below is a photo of the plate on my viper....it's bent! My front heat exchanger also has a slight bend in it. Had the stock access panel remained rigid the object struck would have not been as likely to catch on the heat exchanger.
stingray719
Sign me up for the Viper panel x2.
09nytro
I think the whole aluminum skid plate with the panel needs to be thicker
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
Did trial fit up on our heavy duty access panel and it fit up great. Will be having a batch made. $22 each. Who wants one?
stingray719
One for me please, I may go EVO turbo on other sled and EVO uses that area for a cooler
razor_220
- Dec 21, 2012
- Saskatchewan
- Yamaha Nytro X-TX(sold)
Yamaha SRViper X-TX(sold)
Yamaha sidewinder B-TX
I will take 1 please!!
TJ-R
- Jan 28, 2013
- 14 Viper XTX
I'm in for 1 as well.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
I have an order in for some plates. As soon as they arrive I will be in touch with all those that are interested.
TheWraith
- Sep 13, 2015
- New hampshire
- 20 SRX. 18 Winder 50th
I'm interested. Will this take place of front skid plate?Been working on heavy duty replacements for the nytro, apex/ vector. The Viper panel offers very little protection as well so I am going to produce replacement panels that are thicker. The BOP plates will be aluminum, but twice as thick as the factory plate. They will be a direct swap and mount with the factory hardware. Retail will be $22.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
No this panel is just a replacement for the stock panel right under the oil pan and filter.
yamaha06
So if it's just a replacement for the stock panel, there are no added benefits? I thought it was a thicker and going to add more protection? I don't do much off trail riding, but would like more protection since the stock panel seems very thin, would I be better off just getting a ski plate over this?
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
He had asked if it takes the place of the front skid plate and stated that it is a replacement for the stock panel. The plate is a thicker heavy duty panel for better protection.
$22 is cheaper than I can make it, I will be in for 1!!! maybe some chips come with this one?
Wannaviper
- Mar 18, 2014
- West Gardiner, Maine
Let me know as well, sounds like a great idea!
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
I have some in stock, and they are listed in the online store now. Order them in the store and I will send it out.
We did make one change from the prototype posted. Since our plate is thicker and does not recess flush, we have ground a chamfer on the leading edge so its less likely to catch on objects.
- 9K
