Will fit all Cats, SW and Viper 137 inch track models for 2019. The longer tracks model are still stuck with the trihub.
Same wheels as our Stealth kits have been using but in 8 inch size.
Heavy duty wheels with the larger bearings.
Stock wheels are very cheap and likely will not hold up the studs for long.
Lifetime warranty on axle. $270.00
Will have to call until we get this up on our site
8105450066
Todd
8105450066
Todd
That is a awesome looking piece!
eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
sledding rocks
- Feb 11, 2017
- north
- sidewinder
x2Got mine installed... Really great product. Best part are the wheels use the big 6205 bearings, not the junk 6004's. Second set i've purchased from Todd and are well worth the $270. Cant recommend these enough.
Dr. FeeLGooD
So four wheel kits are for guys who run studs? I'm a Sidewinder newb and my xtx has only two inside wheels. And eightpilot has the coolest avatar ever
The 4th wheel kits are for added insurance against a catastrophic failure of the tri-hub. If you're an aggressive rider or ride in "boney" conditions , I would recommend adding to, or replacing the original tri-hub.
Dr. FeeLGooD
Sheesh..... I really was thinking 21 large would save me some time in my garage fixing stuff for a couple years. Mine is 141. No fix for that? Sounds like I better get the old Nytro patched up for a spare ride.
