Greasemonkey
- Dec 1, 2006
- Somewhere in the Pinelands of NJ
Maybe was posted long time ago and missed it. Has anyone ever installed a 12 or 13mm stabilizer bar on their RX-1's? I have a 2005 so I wouldn't need the upgraded pivots. Just wondering how big a difference it made and how much of a project is it.
MERRY XMAS ALL.
MERRY XMAS ALL.NY_Nytro
- Dec 24, 2004
- Grand Island, NY
- www.gi-snowmobiler.com
If you are going to make the switch then jump right to the 13mm. It will definitely flatten the front in the turns but will also roughen the ride through stutter bumps, the front will dance around more than it did with the 11mm.
It's a very simple job, 10-15 minutes. One tip is that you need to fully remove the bolt on the pivot arm, don't just loosen it and think that it should pull off.
