JAZZ04RX1
- Dec 28, 2003
- Illinois
- 2016 SR Viper LTX-LE
Looking for some info on Heel Clickers clutch set up. I have an 04 RX1 and I am not sure what to use. Heavy Hitters or Heel Clikers???? :?:
Buckeye
- Lakes Region, NH
Heavy hitters
The Heavy Hitters are more popular and a little more versatile. They don't require the bigger and stiffer springs. Other than that it is a matter of personal preference.
JAZZ04RX1
- Dec 28, 2003
- Illinois
Buckeye, can you give me any part numbers or kit numbers for the Heay Hitters to be used on a 04 RX1?
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
Heavy Hitters without a doubt! Get em from Matt at the speedshop. www.thespeedshop1.com
Turbo Tim
MY DEALER RCOMMENDED HEEL CLICKER'S - HAD THEM INSTALLED TODAY, I GUESS ILL KNOW TOMORROW.........
Buckeye
- Lakes Region, NH
Heavy Hitter kit
Jazz04RX-1 Most guys on here are running CPR Stage 2 or 3 Heavy hitter kits from the Speed Shop. I like to do my own thing, so I get the weights and go fom there.
Turbo Tim
HEEL CLICKERS
I just tested my new setup w/ the heel clickers .Dealer installed kit ,
so i dont have specifics although i after reading the installation guide that came w/ them it appears they did as per the instrustions for rx warrior .
they replaced both springs w/ new white springs.-Bottom line is I have a much faster sled for what I use it for , which is pure acceleration .
spent the day in the mountains of Palmer alaska at Hatchers pass , climbed great , seems to be less engine braking , whick is good i think.
engagement went from 3800 rpm to 4800 rpm, I am happy with it .
Turbo Tim
Hey when do i get to Quit being a "newbie"
touched
RXHALLER said:Hey when do i get to Quit being a "newbie"
The magic # is 25 :wink:
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
RXHALLER - Just keep posting. When you hit 25 post you're a Veteran for sure. Takes a lot less time here than in the army....
Turbo Tim
Heater
Has anybody compared hh's to the new hammertimes? would like to know any results that is out there before I buy. Thanx
backonblack
- Nov 21, 2003
I read over on amsnow on the artic cat free forum that a few guys were running the hammer times and they were exploding. Ruined both clutches,belly pan and cracked the hood on 1 guy's sled. They said it looked like air bubbles in the metal. Cheap off shore metal? The guy has had no luck getting hold of Randy at super torquer about the problem. As usual.
b.o.b.
b.o.b.
Heavy Hitters.......Hands down!
Call Matt @ www.thespeedshop1.com
He will give you 100% support, even on a Friday night at 8:00 P.M. when your in your garage working on your sled........Thanks Matt!
Later.......
Later.......
192 Woodys
He will do this on Sat or Sun also. Thanks Matt.
