Helmet Decals
nytrose
Southern Ontario, Canada
I stuck on a yamaha tuning fork round decal on my new modular on the back right above the dot label...doesnt seem to stick so well around the edges because of the curve in the helmet I guess...Is there a type of glue that I can use for this that will work?
try clear nail polish- that might work
next time use a hair dryer to help stretch and form the decal to the contour of the helmet. doesn't take much heat to soften up the decal.
Did you clean the surface off with alcohol or anything before you put the sticker on? Unless that part that's peeling was exposed to air and dirt for a while before you put it on or your fingerprints damaged the adhesive, that sticker should be stickin'! The hair dryer thing is a good idea. In fact, you may be be able to save it by warming it up a little.
