DoktorC
Dead cells will do this...it takes a charge on the charger fine then dies soon after you take the charger off. The dead cells suck energy from the good ones..that added to the draw of the sled itself and the battery goes so flat that it won't keep the ignition circuit and the sled dies.
Change the battery.
Change the battery.
rx1ryda989
- Feb 7, 2007
O ok, I will change the battery, Headin back upnorth tommorow afternoon to do some wrenchin.
rx1ryda989
- Feb 7, 2007
Well tore into her and found the wire was rubbing and broke from the motor to the ecu unit. Going to re-wire and protect the wire like it should have been from the dealer a few years back. The previous owner is a close friend and told me the dealer serviced the wire. Guess not!! Gonna run some tests and hopefully nothing else fried!!! Put the load tester on the battery and it was great!! Hopefully i can have some luck!!
DoktorC
Good Find!!!
rx1ryda989
- Feb 7, 2007
Everythings good, getting 14v at the battery and everything tested out alright, Now that problem is solved, the snow melted!! Always something. Thanks again guys!!
Yamaha205
the snow melted here too
