YAMAMISSILE
I have two inner idler wheels to replace on my 2005 vector. I assume I need to drop the rear skid. What will I need to replace when removing and re installing the rear suspension? Bushings, ect. . .
radianguy
- Jan 1, 2007
Are you talking about the 2 inner wheels up front? if so yeah probably best to remove skid. Remove 2 bolts up front, and 2 in rear where drop brackets bolt to wheels. You need to remove both bolts at front same time, shaft just spins if you don't. Same for rear. When you have the skid out you can check it over and replace anything that's gone.
To put skid back in put front bolts in first then back should go right in place.
YAMAMISSILE
Thank you. Will I need to buy some sort of bushings kit? Sled has 6k miles and is showing some wear. Never had rear skid out.
radianguy
- Jan 1, 2007
not sure, I haven't had the skid out of my Vector yet. I am guessing there is a bushing kit available from your Yamaha dealer and maybe in the aftermarket. Sorry can't help ya more.
shed
if it is the top rear wheels
then yes skid comes out
if you are having trouble with 1 bolt coming out and the other spinning
get a longer bolt same size
put a nut on it and put it in the hole of the 1 that comes out
use the nut like a locking nut and take the hard side out
undo the nut and remove the longer bolt
get a needle that fits on the grease gun (hardware store sells them)
and grease everybearing that you are not replacing
you will be amazed at the water that comes out
the needle slips in beside the seal edge on the bearings
deerhunter1
I use 2 ratchit straps to pull the springs down before reinstalling .
STEVE
STEVE
bluemissile
if you are talking about the 2 inner wheels near the base of the shock you can replace those in the sled.
