Help finding headlight assembly replacement
Force4000
Sussex, WI
Hello all,
I am in a bit of a pickle here. I realized this past weekend my headlight assembly was wobbling on the trail so took her apart and found the plastic bracket that mounts to the metal bar is broken. I can not find a replacement part for the life of me. Its a 2006 Apex RTX. This is what is damaged:
you can see the back part that the bolt mounts to is not there. The only part I can find online to replace this with is this but this looks like the assembly above whats broken. Any help would be appreciated.
http://www.ebay.com/itm/Yamaha-Apex...-15-/391033968984?hash=item5b0b70d958&vxp=mtr
have to buy a new head light pod from yamaha our you can find a use one from parts barn he is a TY er on here that's the only thing you can do.
I had to make mounts for several over the years I made them out of heavy sheat metal and ponded them to the pod. I used JB weld and several small sheet metal screws into waht was left of those tabs to hold it till the glue set.
I also replaced the bolts with the white nylon ones so if I rolled it again the bolts broke first. My X was hell on wheels (skis) and flipped or rolled 3 of them.
Thanks for the reply's. I am going to attempt to make my own bracket to replace it with before I spend the money on a new assembly. I will post pictures if I have success.
I might be wrong but i think someone on this site offers a repair kit for this issue.
Betheviper?
Hibishman?
Barnofparts ?
Few pictures of the ones i made.
I use a piece of nylon plastic from a old kitchen cutting board to repair them. Cut it about 1/2" thick and in a 3 inch triangle shape, fit it in-between broken piece on light mount, used 3 very small 1/8 nut & bolts to attach, used 1/4 inch nut & bolt to attach to existing metal light mounting bracket. Also added plastic weld epoxy ( $8 from auto zone, ) to fill in gapes around it to make it solid. Very strong repair,
Thanks for the advice guys ended up taking everyones advice and made this little sheet metal bracket. Ended up costing about 3.50 for a steel hardware!
Just wondering
Those of you that have busted this part, did it just break over time from vibration??
I have 13000 hard miles on my apex with no issues with the headlight tabs, but it seems like a lot of people have broke them
Mine was just from aggressive riding. I can tell you though that in WI sometimes the trails are... terrible.
all ours were from roll overs or some kind of contact with a hard object to the head light pod.
Bingo. I couldn't find any photos I had, but I made something very similar years back for my 06 GT from a framing hanger I had laying around in the garage.
