NH_Nytro
- May 15, 2011
- Colebrook, NH
- 2008 Nytro
2007 Rs Vector
I thought it would be pretty straight forward to install, I ran power and ground from my battery to the socket, drilled and installed the socket, had 12.0 volts and everything looked good but I appear to have fried 2 gps power cords, obviously something isn't right but what? any help is appreciated.
rx1mtn
Sounds like how I installed mine. I did use 12 gauge wire from the battery to the socket, I also installed an inline 10 amp fuse.
Sasquatch
- Apr 17, 2004
- North Western Ontario
- www.dptc.com
- Yamaha's
Not sure why the cords are fried! Unless the power is reversed! Ground is outside part power is the inside center.
I used a 3 amp fuse as my shield and power point feed off the same fuse and together they draw less then 3amps.
NH_Nytro
- May 15, 2011
- Colebrook, NH
- 2008 Nytro
2007 Rs Vector
Problem solved, cleaned up contact for ground and all works fine, replaced fast acting fuses in cords and now they work again as well.
I was just going to post that your ground cant be good and its most likely grounding through the unit where you mounted the unit.
- 21K
