xcr800joe
- Jan 18, 2007
i just bought a 2003 rx1 er from a dealer, i get it home and it wont rev past 4000 rpm's so i call them and they tell me i need to clean the carbs, so i did cleaned everything up, put it back together now the dumb thing only runs on 2 cylinders and stays right at 3000 rpms, i have spark all the way across, fuel is in the lines, plugs are new... any help here???? my dealer isnt any help whatsoever.. thanks
hlmrx1
Did you take the wires off the plug coils while doing this and maybe switch a couple by accident. I did that once, doesn't run very well. I think it was the first two on the chaincase side.
- Mar 1, 2004
OK;
So you cleaned the pilot jets,as they tend to get somewhat pluged from sitting over the summer or long periods of time. and you have the main jets and pilot jets in their right spot right as I've seem the reversed by mistake.
Make double sure that you pluged the main wires back up to the plug coils tight and that you pushed down hard enough to make those rubber boots click onto the spark plug. Also use a little electric gel as those things tend to have melted snow down those wells which can cause bad conections.
Dumb question but what about your fuel?
YAM182
- Dec 19, 2003
Philscbx
Seems if I let mine sit a while, possible 2 weeks or so, I always have
to spray fuel in to get it running. Never starting fluid.
Choke set full, still doesn't help. I'm about to add electric sprayer to all four. I haven't tested fuel pump, but I may modify this to electric.
Once it's running, it's great. A week later he's fine. But any longer, it's back to taking off air box and squirt em.
xcr800joe
- Jan 18, 2007
thanks for reply guys, this was my first yamaha sled ever buying , as i want ed to try out the 4 stroke..... but after fighting with it for a day, i returned it to the dealer and received my money back as they couldn't figure it out either, so i bought a new polaris again.... wasnt a fan of the rx1 after having to work on it.....i guess ill stick to polaris for now.... love the iq for now...
