drg650
i noticed the one of the pipes leading into the head was leaking. The little bracket the holds the pipe in was broke. ordered a pipe. so when i top up the coolant, how do i bleed the system?
Thanks!
Thanks!
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
there should be a bleed valve in the rear cross over tube in the back of the tunnel be sure the rear is up a little so air will travel to the tube and bleed it there. add coolant as needed.
