4strokesteve
- Feb 19, 2020
- Newfoundland
- 2005 Yamaha Venture RS
THKSNOW
Smooth Operator
- Aug 11, 2006
- 2013 RS Venture GT
I think you can start by removing the bolt (#7) on the outside of the rail that goes into the shaft that the wheel is on. The part that "looks worn" appears to be the inner bearing race from the "broken" wheel. Once the bolt is out, the silver "spacer" part #24 (right of your blue circle) should come out, then the old bearing race should come out. The new wheel will have the bearing in it, and should slide on after you remove the old bearing race. Not too big of a deal, once the bolt is out it should be a no brainer. Because the sled is 15 years old you might want to spray some penetrating oil on the parts the night before you start wrenching.
Here is the microfiche:
https://shop.portyamaha.com/fiche_s...=Snowmobiles&make=Yamaha&year=2005&fveh=33865
Remove rear suspension and go over it all.
It will need more that just this wheel replaced.
4strokesteve
- Feb 19, 2020
- Newfoundland
Thanks for responding THKSNOW and 74Nitro. Would I need to remove the shock as well? I removed the bolt (#7) but how do I get the shaft/spacer above the rail to get it off? This may sound dumb, lol, but I am no mechanic when it comes to sleds.
THKSNOW
Smooth Operator
- Aug 11, 2006
It would be a good idea to pull the whole skid as there are probably other issues. But if you have no mechanical experience or help, you'd be over your head in a hurry. You might need to un bolt the bracket that holds the shock, not sure. Did you try lightly prying on the spacer?
4strokesteve
- Feb 19, 2020
- Newfoundland
I did try prying on it a little THKSNOW. It would move maybe 3/8" or a little better.
if you unbolt the link to the w arm, it should come above the rail so you can slide the shaft out. that is how i do them on 11 apex witch is set up similar.
4strokesteve
- Feb 19, 2020
- Newfoundland
i unbolt the other one, to the right in pic, as that one cannot be put back in with wheels on. hope you are planning on replacing both wheels while you are at it.
4strokesteve
- Feb 19, 2020
- Newfoundland
The one that's just out of the pic to the right?
yes
4strokesteve
- Feb 19, 2020
- Newfoundland
Thanks everyone. Hopefully I can get the problem solved tomorrow.
