justin gallant
- Aug 28, 2017
- moncton
- 2006 apex GT
- moncton new-brunswick
I have a friend's fazer here for service that is hard sometimes to shift from forward reverse and reverse to forward.sometimes I need to wait a while and even rock the sled a little. Any clue????
justin gallant
- Aug 28, 2017
- moncton
- 2006 apex GT
Like its not engaging properly
Gone Blue
- Oct 11, 2006
- Howell, Michigan
This is typical with the Phazer. The system uses an electric servo to engage the reverse gear. So you some times need to rock the sled when you try to engage as the reverse gear teeth are not lined up. It helps to engage reverse with a lower idle speed like under 1,500 RPM. Also its easier to engage reverse when you start the after it idles down. G.B.
justin gallant
- Aug 28, 2017
- moncton
- 2006 apex GT
It's funny you say that ..i found the idle was high..but it does not show the idle on the display!??
Gone Blue
- Oct 11, 2006
- Howell, Michigan
Push the upper left hand button on the gauge cluster that says "SELECT". Toggle thru the displays, ODO, and trip gauge etc until you find the tach. G.B.It's funny you say that ..i found the idle was high..but it does not show the idle on the display!??
justin gallant
- Aug 28, 2017
- moncton
- 2006 apex GT
How do I set the idle on this thing? Found a line with a black knob I can rotate but don't seem to make a difference on my idle setPush the upper left hand button on the gauge cluster that says "SELECT". Toggle thru the displays, ODO, and trip gauge etc until you find the tach. G.B.
YukonMP
- Dec 25, 2014
- Yukon Territory
All about Phazer reverse issues in FAQs
Voda2000
- Nov 15, 2006
- Winnipeg Manitoba
- 2007 Phazer GT 136"
There is a cap on the front left between the a-arms that can be removed and the adjester should be behind it.How do I set the idle on this thing? Found a line with a black knob I can rotate but don't seem to make a difference on my idle set
the wiggle, rock and shutdown reset are all normal from what i have seen.
justin gallant
- Aug 28, 2017
- moncton
- 2006 apex GT
Yup. I got this one to lower the idle from 2800rpm down to 1800. Made a big difference .
Todddejong302
- Jan 1, 2019
- Munising
- 2007 Yamaha Phazer
I have the same problem. So I read this forum a lot and someone recommended getting off the sled and lifting the rear and dropping it. It works every time now. I lift it about 2 inches and drop it and you can hear it shift. Hopefully this works for you too.
