Help w/ ulmer clutch kit baseline
Upstate1000
Cobleskill
14 Viper XTX
Hoping to get some help on where I should be for my initial set up for my weights. I bought this kit from a buddy who sold his sled. The picture is his spec sheet. I have a 2014 xtx. 1.6 cobra. GGB trail can and air box mod. I'm 240ish lbs with gear. Ulmer is closed on the weekends. I wanna get it close so I can dial it in while we have local snow! Any help on initial weight set up would be greatly appreciated. Thanks!
I've been through everything on there. Can't find it. Guess I'll wait until Monday and call Allen
I've got a LTX with MBRP pipe and DIY air box mod. I started 4-0 on the tip and now I'm at 4-4 on the tip and I'm putting 1-0 on mid tomorrow. I keep hitting rev limiter. I'm maxed at tip so hope adding one on the mid fixes it.
Ye
yea these weights have 4-4 on the tip and 2-0 on the middle. Were yours sent with just 4-0 in the tip? Wonder if I should start with that?
This was my last setup with Ulmer Clutching
Power Mods=None Stock
Clutch Kit=Ulmer
Belt=8DN
Belt width and length=1.352
Weights=Ulmer 4washers heel,3washers tip
Helix=Ulmer
Primary Spring=Ulmer
Secondary Spring=Ulmer
Wrap=6-1
Machined for overdrive=No
Machined for 8DN length belt=No
OSP Deflection Adjuster w/plate removed=Yes
RPMS at engagement=3100 indicated
RPMS at top speed and top speed=9160@96mph recall
Miles on Sled=3100
Observations:
Want slightly smoother engagement,100 mph more often
Yes mine came 4-0 at tip
Thanks nytrorider. Anything in heel or middle?
I can't recall heel but nothing in the middle. Sled is in my shop and I can't check at the moment. I'm adding one in the middle before next ride.
