APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
I just bought a pair of Ice Scratchers were do they mount do you have to remove the front outside idler wheel. some pics would be GREAT.
THANKS TY
THANKS TY
woolyviper
- Mar 24, 2006
- hibbing,mn
- 2009 Yamaha Phazer RTX
yamaha has an adapter on their website that allows you to keep your front small wheels and mount the scratchers to the wheel.
CaptCaper
- Jan 1, 2007
- Northern N.H.
I got the mid wheel kit as well as the front wheel kit. I wonder if they'll work with the mid wheels. Being I would need a place to hang them out of the way.
gun nut
scratchers
I bought scatchers from HP for less than $40. Graham has them for $60. What's the deal with that?
Firemann32
- Oct 27, 2007
- Springfield, MO
- www.swmosportbikes.com
I just got a longer bolt for the front set of wheels and drilled the set hole in the rail, if your talking about the original spring style.
Thats on my APEX MTN, I guess I should really update my sig pic......
APEX 06
- Apr 30, 2009
- Sheboygan, WI
ok guys over the weekend I talk to my yamaha guys and they don't know how the adapters from yamaha dose someone here know
Summitseeker
- Sep 14, 2009
Personally I would just remove your front wheels and mount them in the same holes they come out of. Depending on our rails you may or may not have to drill a hole 2 1/16 in front of the mounting hole for the spring. I have iceage rails on just laid them on the top.
Yamaha does have a mounting bracket so you can keep your front wheels but as long as your scratchers are down you will get enough lubrication and the front wheel is not required.
Anybody who knows me.....knows I have a LOT of experince with scratchers! LOL
See pic
See pic
gun nut
scratchers
Seeker,
I was wondering if removal of the frong wheel would cause front of slide to wear, when scratcher is not down. What do you think of mounting scrastchers on the inside of skis?
Seeker,
APEX 06
- Apr 30, 2009
- Sheboygan, WI
was going to do that but haveing a hard time fineing a bolt that long that is not wider
apltx08
Here's another tread with some good info and I also have pics of my set-up... http://www.ty4stroke.com/viewtopic.php?t=77442&start=30
APEX 06
- Apr 30, 2009
- Sheboygan, WI
what are u using for the scratcher.
Firemann32
- Oct 27, 2007
- Springfield, MO
