Help with 2015 rtx dx suspension
Update: I am almost 100% happy after adjustments. To recap-
Put 6 " shapers on inside of each ski, moved stock 4" to outside of ski
Front track spring loosened to very little effort I can turn it
Transfer blocks on 2
Torsion spring in back on 2
Also moved the spacer on the skis so that they are in the wide position
Tightened front ski springs 4 turns from stock. Factory had front springs about as loose as you could go- sled seamed tippy in corners. Quite stable now. Might back them off 1 complete turn. Seems a touch stiff feeling on the handlebars. Pretty happy I would have to admit.trails were some hard pack with 3-4 inches of snow. Some Icey corners. Very rough at other times today. I am around 185 lbs plus gear
Took my sled for another 100 miles today. I loosened front ski shocks 1 turn. Now it is at 3 turns tighter from where it was set up from stock. About perfect now.
