fasteddie
Well just my luck when I pulled the secondary to clean and repack the bearing, the washer (spacer) between the clutch and the bearing fell on the floor. The problem is that I'm not sure which way the washer goes back on. One side is flat and the other side has a ridge on the outer edge.
So, does the flat side go against the bearing or the clutch?
Thanks in advance for any help.
2006nytro
- Sep 10, 2009
id get on yamaha.com and get a scematic and it will snow ya wich way it goes
thrasher
- Nov 22, 2006
- Ottawa Valley, Ontario
- 06 Vector RS ER
Ridge side of washer goes toward the bearing.
Phantom
- Apr 2, 2004
thrasher said:Ridge side of washer goes toward the bearing.
I'll second that... just had mine apart and paid close attention.
