Jayrtx766
- Feb 17, 2017
- New York
- Yamaha nytro RTX
Where is the best place to look for a mountain cooler ? And has anyone tried running Evans waterless coolant in there nytro ?My sled stock would run 220 ish on the temp gauge with the fun light coming on all the time. I added a mountain tech dash vent, mountain tech mountain cooler, and two mod rod vents behind the front shocks and now run Polaris 50/50 coolant (it was in the shelf). My sled now runs in the 175 range all day and just touches the upper 190's on a really long road run. I have not seen the light in 2 years. Or the fan for that matter. I let the sled idle for a the other weekend just to see if the fan would still kick on.
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
I got my cooler "part # 62"from my Yamaha dealer, complete kit was $270 cdn out the door... Comes with everything you need to install...
If you buy just the cooler #63 it's like $410 cdn which makes no sense to me...
It's a great idea to add this, really keeps the temps down in all conditions, never seen the light come on since I installed this cooler...
GYTR GEARHEAD
- Mar 10, 2015
- gatineau
- nytro xtx
evans waterless coolant will make your sled run really hot the fluid retain a lot more heat then standard water base coolant i would stay away from
it if i was you there is a few post about it if you search
mcamzr
I have the mountain tech cooler. I'm not sure if they still make them but I would PM Peter and see if he has any left. It almost doubles the amount of coolant in the sled.
Dr. FeeLGooD
I have the Mountaintech version 0f this cooler along with his console vent. I run 1.75" track and have only seen my temp light on once in about 3 years. I have also installed a temp gauge and the sender screws into part #70. Typically shows a temp of 160*
nydiver
- Apr 30, 2015
- Syracuse, NY
- 09 Nytro XTX
09 Nytro RTX
91 Phazer II (gotta have a classic / kids bomber :) )
If you buy just the cooler #63 it's like $410 cdn which makes no sense to me...View attachment 127890
I'm having a hard time finding this micro-fiche, if you can find it, put up the part# of this kit.
WinderFab
- Mar 1, 2009
- Woodbridge, ON
Nydiver 8HA-124A0-00-00
nydiver
- Apr 30, 2015
- Syracuse, NY
- 09 Nytro XTX
09 Nytro RTX
Finally got it figured out, came back see you posted it. Best I can find right now is 315 USD for the kit. The instructions to it are here:Nydiver 8HA-124A0-00-00
http://ty4stroke.com/threads/instructions-how-to-mtx-tunnel-cooler-kit.77675/
WinderFab
- Mar 1, 2009
- Woodbridge, ON
I know for some reason the US and Canada sites price the kit different, US prices the kit more for the complete kit rather than buying just the cooler but in Canada the complete kit is $250 and if you just want the cooler it's like close to $400 doesn't make sense up here in Canada but that's the way it is, my dealer called Yamaha Canada when I was there and the guy said that's the way they price it here for some odd reason...
nydiver
- Apr 30, 2015
- Syracuse, NY
- 09 Nytro XTX
09 Nytro RTX
Time to take the wife to Niagara falls "be right back...." anything to declare? Besides you're a jerk? Nope
Jayrtx766
- Feb 17, 2017
- New York
- Yamaha nytro RTX
Thanks Fadio was installing the cooler difficult at all ? I'm definitely thinking I'll install one this fallI got my cooler "part # 62"from my Yamaha dealer, complete kit was $270 cdn out the door... Comes with everything you need to install...
Jayrtx766
- Feb 17, 2017
- New York
- Yamaha nytro RTX
Thanks for the heads up on Evans coolant I'll stay away from running that I'm the nytroevans waterless coolant will make your sled run really hot the fluid retain a lot more heat then standard water base coolant i would stay away from
WinderFab
- Mar 1, 2009
- Woodbridge, ON
Jay it wasn't that bad considering that you have to take apart quite a few things, directions with the kit where very clear...
Its definitely worth adding an additional cooler...
- 10K
