NY_Nytro
Can you replace the hifax through the track window ? or do you need to pull the skid.
LooseCannon
No problem through the window.
Swiss Sledder
You may need to cut a window large enough to fit the larger hyfax through. Tork and I changed his hyfax, and Tork used a exacto knife in a soder iron to heat up the blade so it was easier to cut open a window large enough to fit the hyfax through. Still had to take a damn blow torch and heat up the hyfax to get them out. It was a bitch.
welterracer
They are a B*tch to change... but yes they tightly squeeze threw the window..
192 Woodys
If you just pry the back of the hyfax off the rail and out the window put the sled in reverse, give it a blip on the throttle, your hyfax will be laying at your feet. very simple to remove this way. I found I had to take a soldering gun to the right side a bit because it is alittle off center, just did 1 window.
snowstalker
I did not cut my track just work it trough it wil work. P.S. IF YOU use a air hammer its works sweet. think snow!
Sasquatch
- Apr 17, 2004
- North Western Ontario
- www.dptc.com
- Yamaha's
Changed mine out the window with no problem. Never tried reverse. They came out easy with a hammer and screwdriver. Back in with no problems as well. You do not have to cut the windows. They will fit through on an 05 Warrior anyway.
Needed a hammer driver for the screws up front to loosen them. After that it went smooth. Had the job done in half hour to 45 minutes.
Swiss Sledder
Yep, Tork left his at home so we had to use the blow torch.snowstalker said:IF YOU use a air hammer its works sweet. think snow!
RX-Dave
- Nov 14, 2004
Depends on the hyfax. On my 05 shorty, the Hyfax was WAY wider than the windows. But dropping the mono shock skid is a breeze.
donbarb
A little vasaline in the window helps a lot when taking the slidder out or putting the new one on.
RX-Dave
- Nov 14, 2004
on my sled, the hyfax is almost 3/8" wider than the holes.
Sasquatch
- Apr 17, 2004
- www.dptc.com
- Yamaha's
RX-Dave said:on my sled, the hyfax is almost 3/8" wider than the holes.
Yep that sounds about right.
NY_Nytro
Sasquatch said:RX-Dave said:on my sled, the hyfax is almost 3/8" wider than the holes.
But you were able to change them through the window none the less, correct ?
Sled Dog
Sasquatch said:Changed mine out the window with no problem. Never tried reverse. They came out easy with a hammer and screwdriver. Back in with no problems as well. You do not have to cut the windows. They will fit through on an 05 Warrior anyway.
Just heat up the skid with a propane torch a little and the screw comes right out easy. It has loctite on to hold screw in place. Use the blue loctite to put the screw back in again.
rx-1 blue reverse
I have been doing the reverse thing for years. All I do is grab the track and pull it in reverse. I have never actually ran the sled to do this.
