T-Bone
Was riding my 06 Apex GT the other day and both high beam lights were out. Low beams worked fine, but no high beams. Indicator light on the guage goes on and off when toggled with switch. I have adjusted my headlight and run with my highbeams on all the time.
Did just my high beams burn out or is somthing else going on? Seems strange to me if the high beams can burn out that they would both burn out at the exact same time. Could the relay have anything to do with this?
Thanks for the help guys.
SharkAttak
did you check all the wiring? did you check the bulb's?
AIRWOLF
Guest
- Oct 1, 2004
- New York
- www.sledpartsgarage.com
high beams are burned out
T-Bone
Thanks guys, I just did not think that if the high beams burned out that they would havae gone at the exact same time. I guess the Silverstars don't last as long as the OEMs. Don't know what I will replace them with.
