number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
What ended up being the fix for this? My 2018 has started doing this the past two rides.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Place to start would be to check your fuel return line which is under your seat. It was updated years ago from a red plastic elbow, to a black plastic elbow with bigger ID. Mine was replaced a few years ago during some warranty maintenance work at dealer. Some drill out the red instead, and I am not sure what year they started coming with the Black from factory.
blackbay2005
Mine is a 2021 and does the same thing. Intermittent and you can notice it before you stop because the engine breaking is very little.
Turboflash
- Mar 18, 2019
- Southern MN
Check for condensation/moisture in vacuum hose going to MAP. Check MAP solenoid itself for water/dirt contamination.
