builtnotbought
Hey guys, i brought my idle up to about 1600 so that the rattling clutch sound quiets down a little, does this hurt anything ?
That's about where its saposta be about 1500 to 1600 good to go
Bigblue1
- Nov 29, 2007
- NY
- Sidewinder RTX-LE
Apex SE
you sure thats the clutch sounding off or the donuts?
builtnotbought
Its the clutch rattling like they all do and i hate it lol. I wonder how high i could crank the idle without hurting anything ? Even mod the clutch somehow to stop it from rattling...
They say on here its the chain case behind it that is making the noise turning up idle even more might ( don't know for sure ) make it harder to stop use caution if you do that 1500 is where its saposta be if that noise is anoying hit the loud button and it goes away LOL
Mine has been cranked up for years and no problem ! That rattle made it sound like junk
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
The noise is the gear reduction behind the clutch and the 03's were louder because they had straight cut gears but the strongest. 04+ and all apex get the quieter angle cut gears.
No issue having the sled idle at 1750 like I used to to keep it quiet.
builtnotbought
Nice !!!
How was yours cranked up to ?
RX PAT said:Mine has been cranked up for years and no problem ! That rattle made it sound like junk
Honestly I can't remember, I no it's not much. I would check but my sled is still at Hurricane
dhkr123
If your idle is solid and constant (good plugs, clean and sync'd carbs, etc.), you can get a nice firm constant rattle. Makes it sound like a serious machine, kinda that chainsaw-like brutality, but consistent and smooth. Set the idle to 1100-1200 for best results.
Port Snowman
- Dec 1, 2010
- Ozaukee, WI
- snowrunnersltd.com
I thought there might be something wrong with my '03 RX1 because it was so loud at low idle...
Mine is set at 1800 no problems.
