Hindle exhaust install
beetongrizzly
Beeton Ont
Canada
2015 ltx deluxe
Received ful hinlde exhaust today, but came with no instructions, when putting in pipes the shroud under the seat does not seem to fit anymore and there are two brackets to mount muffler and I don't see where they install any help or advice will be greatly appreciated.
Check the website, they might be there, let me know. If not Call Dave at Hurricane or Ulmer...both sell the product
checked web site and no instructions, called Dave at Hurricane and he did not know, called Hindle but they were not open today, anyone have any info about what to do with heat shield
One of the brackets bolts to where the top muffler mount is attached now. The other bracket with the large hole in it uses the rubber grommet from the bottom muffler mount and slides on the pins where it came from. I don't have a heat shield that came with mine, but I just left the stock shield in place. Let me know if you have any more questions. Dave
Thanks for reply that helps alot, the heat shield is the one under the seat, it looks like the new pipes hold it up off the tunnel about 1/4 inch, is this right do I just tighten the screws and pull it down tight. Thanks for the help Dave
It seems pretty close to stock but has a little different tone. I haven't heard it on snow or at speed yet.
