ricks-rocket
- Dec 13, 2004
- Wales,Wisconsin
- 2023 yamaha sidewinder srx le eps
Watched thunder at video and hood was off in 1 minute my srx took about 30 minutes to get off. What is the deal. Not impressed with Yamaha. May apex came off in 15 seconds.
Chris Rose
- Jul 29, 2016
- Powassan ONT
- 2017 sidewinder stx-DX with TD/Max 16 stock muffler
- chrisjrose2018@@gmail.com
Two quarter turn latches on each side and two more just under the side panels and one electrical connector on the upper left side and pull the upper forward. Easy.Watched thunder at video and hood was off in 1 minute my srx took about 30 minutes to get off. What is the deal. Not impressed with Yamaha. May apex came off in 15 seconds.
Crazy Canuk
Agree, it is super easy OP. You may be doing something wrong.
ricks-rocket
- Dec 13, 2004
- Wales,Wisconsin
my new srx has 3 torx screws plus d ring on each side then one electrical connecter.. That is on my 2021 srx so maybe they added more torx screws now. lucky me I can do it alot faster now I I did not know they would be all the torx screws for hood removal.
RAMSOMAIR
Please show where these “new” torx screws are located.
ricks-rocket
- Dec 13, 2004
- Wales,Wisconsin
can take pictures this weekend its back in the trailer right now
ricks-rocket
- Dec 13, 2004
- Wales,Wisconsin
Mototown
You don't undo those , 2 d rings , and electrical connector , then slide hood & head light ...forward, then off
10 second task
putz21
- Apr 15, 2013
- Tomahawk, WI
- '23 Sidewinder LTX LE w/EPS
‘19 Sidewinder LTX SE
Yes, what Motown said. Entire hood slides right off once you do the two d-rings and then the harness.
ricks-rocket
- Dec 13, 2004
- Wales,Wisconsin
yes you are right I did not go far enough into it it is alot easier as one piece.. THANK YOU GUYS i HAVE TO EAT CROW FOR MY COMMENTS
On past Viper models the electrical connection was in the middle and not exactly easy to get at. Yamaha/Cat moved it out where it is easily accessible on Winder models.
Crazy Canuk
My old Viper was definitely more involved to take the hood off than the Winder but they may have improved it on the newer models (mine was a 17).
Glad you found it OP.
